Kia tranny oil change
Old 10-12-07, 07:01 AM
I need to confirm the location of the fill and drain plugs on a manual transmission in a 2006 Kia Optima with a four cyl. motor...lfb
Old 10-12-07, 02:59 PM
HotxxxxxxxOKC's Avatar
Manual transmission are not built the same as auto's, so they do not have a typical dipstick and filler port.
Manual transmissions usually have two bolts on the gear box, one at the top (side) of the transmission, and a drain plug at the bottom/side.
You will have to look carefully for these. Sometimes you need a suction type hose or turkey baster to get the fluid out.
You will refill through the top bolt.
I've never reay heard of anyone changing this fluid on a 2006, are you having any problems?
Trackbacks are On
Pingbacks are On
Refbacks are On
