help R&R power window motor,1993 chevy Astro?
Old 10-13-07, 07:46 AM
Where do you screw in a bolt,so that the window doesn't come down when pulling out the motor?This is what i was told to do,not sure if this is correct.Thankyou for any help you can pass on.
Old 10-13-07, 09:07 AM
well u need to use something to hold the gear to bracket either a bolt thru the 2 or clamp it together so it wont release the spring pressure astros were always kind of a pain to get in and out easy
