Transmission 95 neon
Old 10-15-07, 08:01 AM
B
ok..
so.. I bought this car and a couple of months later I started to stick... from first to second.. then it didn't want to go in reverse. So.. I drained the tranny.. replaced the filter.. new fluid and put in some slick 50.. and IT WORKED.
well now... 8 months later.. its starting to stick again from 2nd to 3rd.. and when I put it in reverse it slams into gear....
so.. obviously I could do another drain and filter but doing that every 6-8 months isnt gonna solve the problem.. so...
What could be the issue??...
When I pulled the plug the last time there were NO metal shavings of any kind. I am not experienced enough to do a rebuild, but any other possible quick fixes would be appreciated.
thanks in advance.
ps.. also having a coolant problem
http://forum.doityourself.com/showthread.php?t=320795
could this be having any affect on the tranny??...
Old 10-15-07, 01:02 PM
B
Any help would be good on this one.
all the gears seem to work.. it just isn't shifting right.. I'm hoping maybe its a sensor or somthing that I can replace...
