91 Chevy S-10 Blazer
Received 0 Votes
Just replaced the front brakes on this baby and need to reset the brake light on the dash. Does anyone know the procedure to do this at home?
Received 0 Votes
Unfortunately it is both, the check brake light and ABS light. Brakes were bled good when replaced and have checked fluids since and no leaks but lights continue to stay on and driving me crazy driving at night.
The check fluid light may have a problem with the sensor in the master cylinder.
I think the ABS light may go with a fault code in the computer.
You can try to clean them off by disconnecting the battery for a couple minutes, but I imagine the fluid light has a sensor problem.
Hope this helps,
Bob
Hope this helps,
Bob
