Thermostat replacement trouble, '01 Buick Century 3.1
Old 10-18-07, 06:47 PM
Cannot get a 3/8" driver and 13mm socket onto bolt(s) and in between exhaust manifold and/or fuel rail. Please explain in more detail how one even gets a socket onto these bolts as I only have two different 13mm sockets and no room for swivels/knuckles; T-body is definately in the way as well. Thanks for your help in advance.
Old 10-18-07, 07:09 PM
top one u can get a 1/4 drive one and sometimea a 3/8 drive between the t-body and exhaust manifold
botm bolt a bit hard u have to go at it with a wrench going between the trans and exhaust pipe
not the easiest one to do in the world but can be done
Brian
Old 10-22-07, 11:59 AM
Brian thanks for the (more) realistic assesment of that job. That was one of the most madening jobs. That back bolt was the worst. I could get a 1/2 in, open-ended on it, but could only rotate the bolt a 16th of a turn at a time. That bolt took two hours. My friend finally used a Sawzall to chop two inches off an old wrench and it went a little quicker.
