ideal "Ignition switch removal"
Received 0 Votes
1994 Ford 150 ignition switch removal. help/ive removed the bottom of the steering column
Received 0 Votes
the only way to easily remove the switch from most fords is to have the key and get the switch into the "RUN" position and use a small punch or paper clip and push in on the small pin on the bottom of the switch then simply pull the switch right of the steering column. If you don`t have the key GOOD LUCK !!!
