98 Mercury Cougar problem
I am a mechanic that also does side work- I have a 98 Mercury Cougar that idles up and down in park. It has a 3.8 and automatic trans.
Thanks,
Ken
Thanks,
Ken
idles high and low
I have a dodge colt I bought for my daughter that is doing the same thing. Changed the O2 sensor and gave it a full tuneup includng cap and rotor. Still happening. I can disconnect the mass air flow sensor and it stops, although put in a new mass Air flow and it does the same thing.
I am now moving to other sensors and then the coil.
Can I ask if you notice a miss when driving, NOT under load? (or when you let of the gas?)
I will let you know If I figure it out
