nissan pick up need help
Old 10-25-07, 02:25 PM
T
1994 nissan pick up, 6 cylinder fuel inj.
what is the fuel pressure I should have???
also, the truck will idle fine, runs for some time til I get t0 3rd gear, starts to bog, will rev back up if I push in the clutch??any ideas ???
Old 11-08-07, 04:27 PM
T
still need help
still looking for help, I have about 35 lbs fuel pressure.
idles fine, ?
Old 11-13-07, 11:54 AM
Try replacing the fuel filter if you haven't already.
Old 11-13-07, 04:45 PM
T
nissan
changed fuel filter. thanks for reply.
Old 11-14-07, 12:27 PM
borak's Avatar
Is the service engine soon light on? If so, what codes are you getting?
Old 11-14-07, 05:18 PM
T
nissan
no service engine lights or any lights on, they light up only when starting so they work.
havent scanned yet.
Old 11-15-07, 09:20 PM
Are you saying that it will stabilize or "go back to normal" when you push in the clutch? That would tell me that it would be a driveline issue. Binding in the trans. or rearend?
Or possibly a dragging brake-drums? --> leaking axle seal or wheel cylinder?
Cheers!
Old 11-16-07, 12:33 PM
T
nissan
not really what happens. its not acting like a drag or bind, more like loss of power, (fuel)?. Ex going down road 35mph, 3rd gear, starts to chug, I can push in the clutch, let it idle for a little and I can have power again. not always.
but sometime. idles great. starts fine. just looses power after roughly 15 minutes or sometimes quicker.
Old 11-16-07, 12:51 PM
borak's Avatar
I'm starting to think it's your exhaust system. Something is resticting the flow causing it to choke itself out or battle itself. By pressing in the clutch your kicking the engine back down to idle speeds where the partially plugged exhaust system can handle the amount of air flow again.
The other check to do is your air filter. Could be that it's starving for air.
Old 11-16-07, 03:05 PM
T
exhaust
the exhaust, that was one of my thoughts, the guy I got it from said he punched thru the converter, so I thought it might have plugged the muffler, the exhaust also had some holes in it and leaked. I replaced the whole system from header pipes to tailpipe. new o2 sensor.
also has new plugs and wires.
Old 11-28-07, 05:02 PM
T
nissan
STILL LOOKING FOR HELP OR IDEAS ?????????????????
