Cavalier idles fast
Old 10-27-07, 08:51 AM
hopkinsr2's Avatar
Cavalier idles fast
Hi, Guys. My friend has a 2001 Cavalier, 2.4l dohc with a 5 speed trans. Hot idle is 1500 turns. I checked for vacuum leaks & found none. Scanned for codes, none. I unplugged the idle control valve & it doesen't change. I'm not famillar with Chevs system, (more a Detroit diesel man ) Does anyone have any tips or more experience on these for suggestions?? Thanks, Roger
Old 10-27-07, 11:17 AM
It may need a firmware version update on the controller.
Old 10-27-07, 07:54 PM
hopkinsr2's Avatar
Huh?? Is this the same as a reflash of the PCM, or are you talking of something else?? Thanks, Roger
Old 10-27-07, 10:06 PM
F
If you have a scanner that is capable of live data you can look at the fuel trims to tell if there is a vaccuum leak....sometimes they can hide. Gasket failure on the underneath side of the intake manifold can be particularly tricky to diagnose.
If the fuel trims are high in indicates a lean condition....test drive the car with someone else monitoring fuel trims. Accelerate to 3 or 4 thousand rpm for a few seconds and if the fuel trims drop considerably than you have a vaccuum leak.
Not to completely rule out a new PCM or reflash, but if I were you I would try this and some other basic stuff first.
