1998 Ford Tauras Blinker Troubleshooting
Received 0 Votes
Has anyone found the secret to the Ford Tauras 1998 blinker / flasher problem that comes and goes.
I have replaced the blinker fuse and the Flasher relay.
Still no blinkers or hasard flashers.
Last time this happened I never found out what was the problem as they started working on their own.
Thanks in advance.
Thanks in advance.
Sounds like a loose wire, or a wire with a break which is hidden by the insulation. Try pushing wires around while you have the hazard switch on, and see if the lights suddenly start working. Try this under the dash and under the hood.
