Power window Regulator VS Motor
Old 11-02-07, 05:42 AM
Have not seen much on rplacing a power window motor. I narrowed down my problem to the driverside PW motor having a problem. I have a 2004 Chevy Tahoe with a cable type regulator.
I have read what it takes to change the regulator assembly but seen nothing on replaceing the motor only.
How hard is it to replace the motor only? How to the cables connect? etc....
Old 11-02-07, 10:31 AM
all u have to do is unbolt the regulator take it out of the door and u will see 3 bolts that hold the motor to the regulator be careful the cable likes to unwind on u
our parts dept tells us you can not get the regulator with the motor anymore they listed as 2 seperate parts
brian
