vacuum Leak
Old 11-02-07, 11:06 AM
H
vacuum Leak
What is the best way to track down a vacuum leak?
92 Dodge Colt Mitsubishi engiine.
Old 11-02-07, 12:26 PM
Received 30 Upvotes on 29 Posts
First move and reset connections that are accessible. If that doesn't find the leak, you can spray WD 40 around connections and mating surfaces.
Keep in mind there are air valves and vacuum driven devices that can have leak faults internally.
Hope this helps,
Bob
Old 11-02-07, 09:47 PM
You're ears.
Listen for the hissing sound.
Old 11-14-07, 11:25 AM
H
cold out car runs great, warm car runs bad
Not sure now if it is a vac leak. Checked everything possible. Except of course somehting tha is internal. Most connections (small hoses seem new, like the dealer was trying to find the problem before I bought the car) It is cold out now so the car runs great, as soon as it's above 50 degrees outside the car misses, bucks,and idles bad
