Problems with a 1995 Chevy Cavalier
Old 11-03-07, 07:29 PM
Question Problems with a 1995 Chevy Cavalier
I have a 1995 Chevy Cavalier that will not shift passed the first gear. Does anyone have any suggestions or solutions to help solve my problem?
Old 11-04-07, 04:25 AM
Cool Problem solver
Your 95 cavalier is a automatic transmition .If so check to make sure the fluid level is up.This check should be done when the engine is hot.If the level is up to the top mark then check the emogilator valve on the trans.The vacume line on it can be pluged with [gas,water,condensation,ect.] this can cause problems.Pull off the line and drain.Next it could be a linkage problem.RICK
Old 11-04-07, 11:03 AM
1995 Chevy Cavalier
Thanks Rick, I will try it to see it that works. Every little bit of information always helps.
Trackbacks are On
Pingbacks are On
Refbacks are On
