tranny help needed
Old 11-05-07, 01:50 PM
tranny help needed
hello.
i have a 94 caravan 3.0 125k with a bad tranny
the months before it died, i heard lots of rapid clicking from behind the bottom of the radiator. do you think this was the solenoid? do you think my prob might be the solenoid? is there a way to flush to solenoid? is there a "magic" tranny flush i should try? the tranny has been acting up for at least 6 months (wouldnt shift out of first, threw it in nuetral, shut it off, restarted it while driving, drop back into drive, and this would solve that problem) so im guessing i destroyed it.....any thoughts would be greatly appreciated.
mark
Old 11-06-07, 02:52 AM
F
If it is clicking then the first place I would check is the "flex plate". Remove the inspection plate below the trans and have a friend rotate the engine 360 degrees by hand and inspect the flex plate.
Do you have a friend that knows vehicles that can help out?
If not, this might be a job for a pro.
