03` trailblazer trouble code 1345
Old 11-06-07, 03:06 PM
reyes45's Avatar
Question 03` trailblazer trouble code 1345
My trailblazer`s chek engine light whent on and I scanned it for codes. The code 1345 came out. Iknow what the code means but what is causing it. It has a inline 4.3L 120,00mi.
Please help. Thank you
Old 11-06-07, 05:01 PM
HotxxxxxxxOKC's Avatar
Either the cam sensor is going out, or you might have a timing issue. Have the vehicle hooked up to a scan tool so they can read your cam retard/timing.
Old 11-07-07, 05:21 PM
reyes45's Avatar
Thanks, sounds like something I can`t perform my self so ill take it in. Ill post my results. Tanks again
Old 11-08-07, 05:51 PM
Have you had the distributor out for any reason because this is a corelation code for the crank and cam sensors !!
Old 11-08-07, 06:05 PM
no dist in the trailblazers they are coil on plug
could be a senosr prom or cam actuator problem to many to guess
Old 11-10-07, 12:22 PM
reyes45's Avatar
So, everyone agrees that I should take it in and have it diagnosed. I was affraid of that. Is there anything I can check with my multi-meter?
Old 11-10-07, 06:00 PM
Looks like the main tool for this DTC diagnosis is gonna be a Tech 2 scan tool that the dealer has.
Trackbacks are On
Pingbacks are On
Refbacks are On
