Have to prime throttle body to start
Old 11-10-07, 07:42 AM
I have a 1987 Chevy Blazer V-8. Put in a new fuel pump and gas regulator and the truck still won't start. I can prime the throttle body and it will start and run, shut truck off, won't start until I prime it again. Can anyone help?
Old 11-10-07, 06:08 PM
Assuming you are getting pressure to the central point injectors, it only leaves the injector signal or a vacuum leak. How are the idle rpms after it gets warmed up? If they're normal, that leaves the cold start signal to the injectors. A chance it's a computer problem.
I would get codes pulled to see if anything shows up. Meanwhile maybe some of the Chevy guys here will jump on this thing.
Hope this helps,
Bob
Trackbacks are On
Pingbacks are On
Refbacks are On
