2000 astro van
Old 11-10-07, 08:34 PM
H
2000 astro van
had occasional starting problems, got worse, changed fuel filter, got worse, wont start without a shot of starter fluid
Old 11-10-07, 10:48 PM
Next time you go to start it, turn the ignition on for 2 seconds, then turn off. Repeat this 3 times and then try to start it. It should start, indicating insufficient fuel pressure. You van requires 65 psi of fuel pressure to start. It will run off 50 + psi. Sounds like you need a new fuel pump.
