PCV Valve location 98 Camaro V6
Can anyone tell me where the PCV Valave is located on a 98 Camaro V6. I have looked every where and can't find it.
Thanks
Thanks
Typically PCV valves are stuck into the one of the valve covers. If it is not obvious, look for a small ~0.25-0.5" fuel line type rubber hose connecting from the intake manifold to something that could vent the crank case. If you still cannot find it, go back to the fir filter and follow the air duct to the throttle body. Any hoses that come off of this duct, trace down and see if you find the valve at the end of them.
