'03 BMW X5 oil change.
Old 11-12-07, 01:31 PM
Hi guys, I'm on the "need help" end again. I'm changing the oil and filter on an '03 Bmw X5 and would like to re-set the service interval indicator. The BMW shop is unwilling to tell me how to do that so I'm here, asking if anyone can tell me how to do that. Thanks a lot in advance.
Old 11-12-07, 06:03 PM
billys68ss's Avatar
For model year 2001 the E39, E46, and E53 will eliminate the 20 pin diagnostic connector from the engine compartment.
On 2001 3 Series and 5 Series vehicles without the diagnostic connector in the engine compartment, the SII reset tool can no longer be used (see note below). Instead, the SII can be reset with the trip odometer reset button in the instrument cluster, following the procedure given below:
The ignition key must be in the "0" ("off") position.
Press and hold the trip odometer button in the instrument cluster, and turn the ignition key to the "1" (accessory) position.
Keep the button pressed for approx. 5 more seconds until any of the following words appear in the display: "Oil Service" or "Inspection", with "Reset" or "Re".
Press the button again and hold for approx. 5 seconds until the words "Reset" or "Re" flash.
While the display is flashing, press the button briefly to reset the Service Interval. After the display has shown the new interval, the following will appear in the display for approx. 2 seconds: "END SIA".
The system can only be reset again after the vehicle has been driven approx. 50-75 miles (consumes at least 2.5 gal. fuel).
If the display shows "Reset" or "Re" when resetting, the minimum driving distance has been fulfilled and the system can be reset again.
It is possible to interrupt and end the reset procedure by changing the position of the ignition key.
Note : An alternate method to reset the SII is to use the OBD adapter harness (available under P/N 90 88 6 614 300, sent to all BMW centers as part of the Automatic Tool Shipment Program) together with the SII Reset Tool (available under pin 88 88 6 621 110). Fasten the Reset Tool to the OBD adapter harness, then connect the harness to the OBD/diagnosis socket in the driver's footwell. Reset the SII per usual procedure.
I realize this says 2001, but in Alldata with a 2003 model selected, this is the info that came up. Im sure the procedure is probably still the same.
Hope this helps ya,
Billy
