Squeaky clutch pedal
Old 11-15-07, 06:14 PM
2001 Nissan Maxima, 170k miles, just had clutch slave cylinder replace, and now the clutch pedal squeaks when engaging/disengaging. Does something simply need to be oiled/greased or is there a more serious problme?
Old 11-15-07, 07:39 PM
The pivot for the clutch pedal itself would be the first place to look and lube.
But since you've just had the slave replaced, it could be a squeak coming up from that cylinder. If so, it may work itself out the more you use it.
Hope this helps,
Bob
