1994 Toyota Corolla brake light problem
Old 11-19-07, 10:01 AM
D
I have a 1994 Toyota corolla, the 2 bottom rear brake lights work fine but the high mounted brake light (collision light) doesn't work. I have replaced the bulbs but still won't work. Any ideas? Thanks.
Old 11-19-07, 04:05 PM
E
Received 1 Upvote on 1 Post
Sounds like you are going to have to physically trace wires. Since rear ones work, that or the bulb or socket or ground(wire) is about all that's left. Maybe the wire is routed somewhere where activity in the trunk or under the car or beneath the carpet got it damaged/snagged, or it got corroded?
You'd think that a wire would be pigtailed or otherhow spliced/connected to one of the rear lights to go up to that rear window? light, and you'd just have to go back there and start following it. The problem may even be right at a splice/pigtail or other joinery at either the rear lights or the window light. This may be a little time consuming. But I'd guess that of all the wire tracing problems one could possibly encounter about a car, this one would have to be about the easiest, from the fact you already know where you DO have power at, and it's not a switching, fuse, or other issue.
Old 11-20-07, 07:56 AM
D
Thanks Ecman51. I guess I'll start at the rear brake lights and work my way back. Any possiblity that anyone has a wiring diagram?
