98 s10
I still have no idea what you are saying.
Is check engine light on? If so, get a OBDII scanner and read the codes.
Received 0 Votes
Are you saying that you replaced the computer and the fuel pump? Did you reprogram the computer after replacing it? If not, it won't start because the anti theft system has not been programmed. You initial problem could have been just an anti theft system problem. Did you check the oil pressure sensor? That could disable the fuel pump if faulty.
As stated, we cannot help until you specify a little clearer on whats going on, and then get us some DTC's so we can look them up.
