1995 astro door handle
Old 11-25-07, 05:16 AM
W
Question 1995 astro door handle
How do you replace the out side drivers side door handle, Not the handle you pull on, the part behind it. it is broke in half.
Old 11-25-07, 12:11 PM
It's part of the handle. Go buy a handle. Remove the inside door trim panel and roll the window up. You will have to unfasten the lock cylinder rod and the door latch rod. You then remove the bolts that secure the handle to the door, I think there are 2 of them and use a 10mm socket.
