Help with a bolt !!
Old 11-27-07, 02:31 PM
Help with a bolt !!
I'm trying to change the power steering pump on a 1997 Toyota Corolla. I took out all the bolts that need to be taken out except for one. I'm not sure if there is a special procedure to do that. It is called: pressure line-to-pump banjo bolt. It is a regular bolt with a star in the middle. I found a socket that fits it perfectly but no matter what I do this bolt isn't turning. Any help/tips appreciated.
Old 11-27-07, 03:07 PM
HotxxxxxxxOKC's Avatar
You need to get a large breaker bar and try and remove it. These things are notorious for being VERY tight.
A simple ratchet does not have enough torque.
Old 11-28-07, 08:02 AM
Thanks a lot Mark ! The bar trick worked. I apprecite your tip.
