Bench grinder question
Installing wire wheel...fasteners rotate in clockwise/counterclockwise directions.
How does one tighten wheels?
TIA.....
Wonholly....mechanically challenged
TIA.....
Usually the retaining nut tightens clockwise with the grinder rotating counter clockwise. Tighten the nut as tight as you can with whatever available wrench you have. When you start using the grinder/wire wheel the wheel against the retaining nut will finish the tightening for you.
Hope this helps,
Bob
Hope this helps,
Bob
