What is the timing set for a 4.3 motor
Old 11-30-07, 05:42 PM
Question What is the timing set for a 4.3 motor
Hi can anyone tell me what the timing should be set at for 4.3 motor in a 1988 chevy truck .
I looked in my book but it did not tell me ' it said to look on the truck . And I can't find it there .
PS: And what is the idle RPM suppose to be set at.
Thanks
Old 12-01-07, 05:08 AM
the_tow_guy's Avatar
Received 181 Upvotes on 143 Posts
Looks like 700 on the idle, not adjustable if it's fuel injected. Timing 4 deg BTDC for manual trans, automatic - "see underhood info". Hmmm. Maybe someone knows; in the meantime you're probably safe using the 4 BTDC.
On carbureted engines you would need to disconnect the vacuum advance line to kill the advance on the timing. On injected models there should be a small connector visible near the distributor that must be disconnected to accomplish the same thing prior to setting timing.
Old 12-01-07, 08:17 PM
R
Received 1 Upvote on 1 Post
Set timming on 4.3
I believe fuel injection started in 87 so your idle speed would be computer controlled. RW
