Possible timing belt installation malpractice ???
Old 12-01-07, 03:55 AM
Question Possible timing belt installation malpractice ???
Hello everybody:
I bought a used 1999 Daewoo Lanos LS car.
The motor is 1.6L DOHC E-Tech
I paid $ 125 for the timing belt replacement , water pump and oil seals , I bought the parts ,, I only paid for the labor ..
Right now I feel the motor with less power ..
I don't know if my feeling about the power of the motor is wrong ..
My question ....
If the CAMSHAFTS are not perfectly align .. is possible to have a motor running well but with less power ..
Could be my imagination is playing with me ....
Please help me .. !!
Old 12-01-07, 07:26 AM
I'm not familiar with this vehicle or it's engine, but the belt may have been installed a tooth off. I know on the old Dodge Intrepids we used to do, every now and then we would get it a tooth off. In these cases, the car ran alot better.
Old 12-01-07, 11:54 AM
daswede's Avatar
If you noticed this just after the t- belt change, it may be normal till the computer adjusts for the new belt. If its been awhile,3-4 days then it might be something else.
Old 12-01-07, 01:44 PM
hey,im new here and dont mean to "ruffle" any feathers,but the computer in your car has NOTHING to do with timing belt replacment,it is a mechanical attachment from your crankshaft to your camshaft,and while its possible that it may be a tooth off,its highly doubtful,if it was,there would be a serious lack of power,being that its a 4cyl,it will put all your valves out of time,on a chrysler as mentoned above,a v6,its possible to be off a tooth on one camshaft,and not the other,hence the still running half way decent,but you only have the on cylinder head, hope this helps
Grant
Old 12-01-07, 08:14 PM
the_tow_guy's Avatar
Note that he has a DOUBLE overhead cam, so one side (intake or exhaust) could maybe a tooth off? Not sure how the cams/belts are configured on that engine.
Also, this is a valve bender engine, so having valve timing off would be a REALLY bad thing.
This was a reputable repair shop, elchicloso?
Old 12-02-07, 04:49 AM
Question The belt move like a serpent !!!
Thanks Guys for feedback:
This repair shop is new for me .. is my first time with it ..
The motor is noisy when I accelerate it (near the belt assembly) .. I am scare about that.
The consumer report said .. the motor is noisy.
Could be that noise is normal .
I remove the timing belt cover and the belt move like a serpent (not to heavy) could be 1/8 inch side to side.
That belt serpent motion is normal for a new belt ?
