Motor oil in tranny?
Received 0 Votes
Yesterday, I accidently added about 2 ounces of 30wt. motor oil into the tranny of our 91 cavalier, before realizing I had the wrong can in my hand. NOW do I need to have it towed to garage to get it totally emptied or, will it damage anything? Thanks for any help
Motor oil doesn't work very well in a transmission, but the ratio what you have in it to the other transmission fluid is pretty small. I wouldn't go to the expense of having it towed. I would add some automatic transmission fluid conditioner to bring it up to level and call it good.
If you haven't changed the fluid/filter in the car and you wanted some peace of mind you could have the transmission serviced, but still, I wouldn't tow it anywhere just because of the two oz of motor oil.
Hope this helps,
Bob
Hope this helps,
Bob
If you haven't started the engine after doing this, the engine oil is still in the tranny pan. There should be a bolt that you remove on the pan to drain the pan.
tranny drain
I've only seen this drain on heavy duty trucks , 2500 and 3500 , not on regular cars.
