'98 Sienna autobody repair situation
Old 12-03-07, 11:56 AM
Question '98 Sienna autobody repair situation
2 years ago a guy ran a stop sign and t-boned my front driver-side door. I took to an autobody repair shop. After the repair, the power window usually worked, but once in a blue moon, it wouldn't come up. With a good, hard slamming shut the door, it would come right back up. The infrequency was never bothersome enough to take it back to the shop.
However, Saturday night it happened again and now it refuses to come back up. I took off the inside paneling and took a peek inside. I reached down in the bottom of the door and pulled out about a 16 - 18" long curved piece of metal lined with a rubber gasket. I took the passenger side door apart to see if I could match this part and it is a guidance track for the window to travel up and down.
Now my question is this, is the power window failure a result of the body shop not putting the window back together correctly, which caused damage to the motor or something in the inside alignment or is this just coincidence?
Thanks for any insight - I can use an experienced opinion.
Old 12-03-07, 02:43 PM
HotxxxxxxxOKC's Avatar
Depending on your insurance company and the body shop, this repair could be guarenteed for life so check that out.
The repair shop might not have replaced the internals of this window and just pulled these components from the damaged door.
It would be hard to prove this, but you might talk it over with the body shop. If you're polite, they may fix it for you seeing that you/insurance company, gave them alot of money to repair it.
Power windows go bad all the time, so it's not uncommon.
Old 12-03-07, 02:53 PM
Thank you - will do!
