Resetting Check Engine Light On 88 Ford Tempo
Old 12-04-07, 03:53 PM
D
Looking For Information On How To Reset The Check Engine Light On A 1988 Ford Tempo Xl 2.3 Litre Engine.do I Have To Take It To A Ford Dealer Or Is There An Alternate Way?
Old 12-04-07, 05:48 PM
K
its still alive?
its an o.b.d. 1 system. if it is still on, then there is probably still a problem.
just for kicks, you can disconnect the battery and wait 10 minutes. this will clear your k.a.m. memory. your car will have to re-learn all sensor values. if the light comes back on then you definitely still have a problem.
Old 12-04-07, 06:03 PM
Received 1,197 Upvotes on 1,152 Posts
Disconnecting the battery is the simplest way.
Old 12-05-07, 04:15 AM
the_tow_guy's Avatar
Received 183 Upvotes on 145 Posts
If the light comes back, here's info on how to read the codes:
http://www.troublecodes.net/Ford/
