88 Celebrity Radiator fan
Old 12-05-07, 09:41 AM
R
I have a radiator fan that runs for a few minutes after the car is turned off. It has just started doing this in the last week. Can someone give me some troublshooting advice on this problem. Thanks in advance.
Old 12-05-07, 01:58 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
This usually only happens in the heat of the summer when the coolant is excessively hot and needs further cooling after shutdown. It is normal. However in the dead of winter, unless you are low on coolant it should not be doing it as much. You may have a bad heat sensor on the radiator which tells the fan to come on and turn off.
