Oil light on and foff
Old 12-08-07, 02:52 PM
I think my '01 Malibu might be kicking the bucket soon.
This week for the first time ever my oil indicator came on then went off and then at least once a day since Monday.
I am due for and oild change but not much over the 3,500 mile mark and i did notice I was down about 1/2 a quart last week.
I've never known it to burn oil and the engine sounds normal.
It's got 180,000 mile on it maybe it's the sender.......mmmm, don't know or maybe it's the pump........mmmmm.
Last time I delt with this kind of problem it was a '67 Skylark, I changed the oil and never got oil pressure again from that point on,........ it was the pump.
Haven't done an oil pressure test yet, maybe I should go there first.
Any suggestions, I'd like to get another 100,000 out of it the body and interior are perfect but I have noticed the trans slipping if I have to nail it from a dead stop otherwise it's fine.
New cars ('07 left overs) are at 0 % intrest for 60 months to......hmmmm?
Any body, any body.........Buhler........Buhler........?
Old 12-08-07, 07:30 PM
the_tow_guy's Avatar
Received 242 Upvotes on 195 Posts
Lot of miles on an '01, but I think I would give the sender unit a try; pretty cheap fix if that's it.
Old 12-09-07, 06:35 PM
Yea, the sender will be my first try.
Changed my oil and filter and I didn't see any metal in the oil or any junk in the filter which is a good sign.
I did pull the sender and it lookes good but you never know.
I'll run this week and see if the light comes back on.
Old 12-09-07, 07:09 PM
Received 2 Upvotes on 2 Posts
My first thought is that the light is kicking on because it is low
And only occasionally because it's not "too low" just yet
I've had many cars that do this
-though admittedly it's usually a quart low for the light to kick on occasionally
Still...that's the first thing that came to my mind
