95 Ford Aspire - No spark
Received 0 Votes
I have a 95 Ford Aspire. It ran fine when I parked it in April. Wife used it to jump start the truck while I was deployed. I found the master fuse blown, changed it, and I have power now. But it still won't fire. Distributer/ignition control module ohm check good. Manual doesn't give you an direction past this point. Ignition fuse under hood is good. What should I check next?
I would be checking codes to see if something like a crank or cam sensor code comes up. Here's some testing help:
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
