nogonomo (Wiring Problem?)
Old 12-10-07, 04:32 AM
92 cougar 3.8 quit waited a few min it started done this a few times then would not start at all toed to shop they replaced fuel pump run good for awhile then same thing they replaced relays same thing happend when you turn on the key and you here the fuel pump buss it starts but sometimes you here it click in the trunk and the fuel pump don,t come come on fuel shut off ok help
Old 12-10-07, 05:03 AM
the_tow_guy's Avatar
Sounds as though you may have a wiring problem; it's going to take some good detective work with a multi-meter to track it down. My first thought is that it is related to the shut-off.
Old 12-13-07, 06:10 AM
chandler's Avatar
Agree with TG. The crash sensor could be the culprit. Maybe replacing it would help. But a good diagnosis is in order.
