96 camry starter problem
Received 0 Votes
I have a 96 camry, 4 valve engine. I was having problem starting the car for a month or so. It used to make a click sound but won't start, but after trying it for 5-6 times, it would start.
Since yesterday the car won't start at all. when I turn on the ignition, I hear a click sound and the sound of some motor running. When I tried this with hood open, I think the motor running is the starter ( not sure).
Is this a starter problem or something else.
Can someone post steps to replace the starter.
I would really appreciate any help.
Thanks.
Thanks.
You need to double check to see if the "running" sound is actually coming from the starter. If it is you may need a new starter. If the running sound is something else, then there's a very good chance that all you need is new contacts and a plunger in the starter solenoid. Toyota starters very rarely good completely bad, but often the solenoid contacts eventually wear to a point where they no longer make a proper connection. The difference in cost between replacing the starter and replacing solenoid contacts can be as much as $200.
More info:
http://www.autozone.com/az/cds/en_us...es.htm#hd1-1-3
More info:
Also, here's info on the solenoid and how to repair:
http://www.4crawler.com/4x4/CheapTricks/Starter.shtml
