No Cylinder Pressure
Received 0 Votes
I have a 94 Grand Prix SE with a 3.1...i recently put all new gaskets from the head up due to overheating and no heat. I also had the heads checked out for warps and cracks and they were good. The car ran fine before just had an overheating problem, and now i have no cylinder pressure. I have checked and made sure i had all the push rods in the right places and i do...any ideas would be greatly appreciated!
Received 0 Votes
yeah it seems it would have to be the valves sticking but how could they all stick...i have no pressure in cylinders 2,4 and 6 haven't checked cylinders 1,3, and 5 in the back but the plugs were wet with gas so im assuming they don't have pressure either. The car had decent pressure before i riped it apart...so it had to be something i did...i did replace the valve seals i wonder if i could have did something wrong there...i did them one at a time so not to put one in the wrong spot and did them by the book. Its has to be the valves because its a big leak im not even getting a budge on the dial on the pressure tester. I guess i might have to tear it down again...any advise on what i should look for or should i just take the heads and valves in and have them looked at again...
thanks
james
thanks
james
what torque setting did you tighten the rocker nuts to?
It could be you simply did not tighten them correctly and the valves simply are not opening.
Do not go and willy-nilly tighten them up. There is a correct setting.
Received 0 Votes
Do you even know that your valves are going up and down? A rotating engine does not guarantee the valvetrain is even working. You could have timing belt or chain come off even. Is it hard to take off valve cover?
Received 0 Votes
The first thing you have to do is a cylinder leak-down test to see where the pressure is leaking to. Might be the valves stuck open if you tightened the rockers too much, might be the head gasket leaking if not tightened enough, might even be cracked pistons or rings from the overheating.
Received 0 Votes
Eveything is torqued right head bolts to 33 ft-lbs and then rotated 90 degrees....rocker nuts torqued to 20 ft-lbs...spacers are in...took out push rods and tested pressure and perfect pressure...so its nothing cracked...so it must be the cam or the lifters...timing is correct so its not that...guess its time to take off the upper and lower intake to check out the cam and the lifters...thanks for all the tips!
Received 0 Votes
Are you sure the chain/belt has not skipped out.
I still would have a quick check on the base valve timing to make sure that it did not skip a cog with that heat
Last edited by frankiee; 12-11-07 at 02:14 PM. Reason: Thinking of wrong engine: Im ok now; maybe!
I was just reading something. It said the pushrods (intake v. exhaust) are different lengths.
the intakes are 6 inches long and the exhaust 6 3/8 inches long. Reversing them would surely cause some problems.
