95 altima again sensor issue?
Old 11-19-07, 08:47 PM
P
95 altima runs rough and dies if you hit the gas
hi i have a 95 altima with about 160k on it just put in brakes and drove to the twin cities and back and when i started it up the next morning it ran fine till i was about halfway to work and it sputtered and died couldnt restart it had it towed mech couldnt find the problem towed it home and it strted right back up the next morning but runs really rich and the motor kicks pretty hard like its misfiring exhaust is almost greyish/black but no oil loss on the dipstick no loss of coolant or other fluids runs really rough but if you press on the gas it kicks hard then dies i need to get this fixed b4 the snow flies as i dont like the bus or taking a taxi those are very very expensive now that duluth has a free market on them, anyone know what the problem may be would be a great help, i also have a 94 ram 1500 with brand new fuel pump runs fine but the gas guage always reads empty or a hair above empty friend said it needs to have the guage reset or somthing of the sort the ram has no plates so i cant drive it but i need to fix the car as i was getting about 35 mpg b4 it started acting up.
Old 11-20-07, 04:19 AM
the_tow_guy's Avatar
Received 198 Upvotes on 158 Posts
I assume the mechanic would have pulled codes, but just in case, you can check them yourself. Here's how:
http://www.troublecodes.net/Nissan/
You'll need to locate the ecu.
One of my first suspicions is that you may need an O2 sensor. Did the gas mileage go down the toilet, i.e. is it sucking gas like there's no tomorrow?
The sensor can be tested if you have a meter:
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old 11-20-07, 07:17 PM
P
response
o2 sensor replaced worked good for about 30 seconds then went back to the way it was i got the ram fixed but the nissan has an issue i checked the timing and its still good chain didnt jump and rotor and cap are good wires are good i will be checking on the plugs in the morning maybe fuel filter or a vacuum issue?
Old 11-21-07, 04:47 AM
Not likely fuel filter; a clogged one would make it buck and/or die, but not run super rich as you describe.
Were you able to pull codes? Good starting point.
Old 11-22-07, 07:47 PM
P
says maf sensor failure but tried unplugging
unplugged the maf sensor both temp and air flow plugs and it ran fine for about 30 seconds then went back to doing what it did before it read error code misfire cyl 1 (replaced plugs and wires and the coil code gone now) now it said error code air temp sensor failure now it wont start and stay running for more than 20 seconds at a time and it still bucks and runs super rich
Old 12-13-07, 05:56 PM
P
Exclamation 95 altima again sensor issue?
wondering if a crank or cam sensor could cause it not to run or even start i had the timing checked its right but i replaced the ecu and tcu with certified reconditioned parts and replaced every emissions sensor and intake sensor and replaced the maf unit.... now heres the hard part anyone know how to get it moving without shoving it down a steep incline? i need this running soon as the truck is a real gas hog with 45 tires in the back of it (yes i sell tires on ebay folks but still can only afford a p o s beater car if i could just get it running right i would sell it and buy a suv or hopefully get my hands on a working 83 cressida with either a 5mgeTT or a 2uz-fe with twin quick spool banks turbos i had an 83 cressida and man she was beautiful fast and hugged the road like you would some hot chick you just married....) now back to the car i have dumped about $1400 into it now what? how much to get it running and what parts do i have to replace?
Last edited by HotxxxxxxxOKC; 12-13-07 at 07:28 PM. Reason: ++ Merged your thread into your old one++
Old 12-14-07, 01:26 PM
Wow. A lot more $ than I would have spent on it. So from your description and dialogue I'm guessing it cranks over but won't fire/run?
Old 12-14-07, 02:44 PM
Received 30 Upvotes on 29 Posts
Some one here on the forum here had a lot problems of with a Nissan, I believe a 98 Altima, couldn't get it run right, and replaced the distributor on it. He said it took care of everything.
That may have had a faulty camshaft sensor with the distributor.
I don't remember what he had for symptoms. I believe it just quit on him.
Old 12-16-07, 03:41 PM
P
already replaced distributor but didnt fix the issue
i will see how much a crank sensor costs and i hope that fixes it this is my only car that has good tabs and doesnt suck gas like a late model dodge
Old 12-17-07, 01:53 AM
N
Hi, This post of mine is very beneficial and informative, however there are some specific facts or information that I require. If anyone can help me in this matter then please send me a private message. Best Regards,
Property Directory | Wholesale Billiards
Wholesale Batteries
Something Directory
