Evertime i start my 1989 Ford Escort it stalls out
Old 12-14-07, 07:29 PM
A
Question Evertime i start my 1989 Ford Escort it stalls out
Evertime i start my 1989 Ford Escort it stalls out then when i try to start it again it take longer to start or won't start at all i changed the battery and all the fuel sensors and i changed the atlantor and everthing i could possible think of what can i do to fix this PLEASE HELP
Old 12-15-07, 11:16 AM
the_tow_guy's Avatar
Received 241 Upvotes on 194 Posts
Moved you post to a new thread. Please use the "New Post" button when asking a question rather than adding to an existing thread (especially a 7 year old one).
Old 12-15-07, 11:20 AM
Need to start with basics, spark and fuel. First determine if it has spark during a period when it won't start by pulling a plug wire and seeing if you can get a spark to ground (be careful not to get shocked).
Next item, fuel. You will probably need to check fuel pressure which may or may not be DIY in your case. As a cheap "couldn't hurt" measure, you might try changing the fuel filter.
