cold start problems
cold start problems
I have a 97 explorer when I start it. it starts running from high idle to almost killing and does this until it worms up.Also when I put the defrost on the air compressor keeps kicking in and out. thanks Ken
The engine surging up and down at idle is usually a sign of a vacuum leak. You didn't say which engine you have but if it is a 4.0L SOHC, upper intake gaskets are very common on those. If it is a 4.0L OHV the o-ring on the EGR tube is very common. Both can be easily checked, start the veh cold, and spray the areas mentioned with carb cleaner/choke spray. If the idle comes up and the veh runs normal, you have found the problem.
If the vacuum leak areas check out, the idle may just be the fast idle for a cold engine, and the dieing down is from a bad water temp sensor.
I had about the same problem with my Ranger and a 2.9. It did OK when the weather was down in the single digits to teens, but anything above that I would get the normal fast idle, then the engine would either die or slow down and surge until it was warmed up. I replaced the water temp sensor for the computer and it been fine ever since.
Hope this helps,
Bob
Hope this helps,
Bob
Thanks for the info I'll check it out. Mine seems to be doing it when the weather gets colder!
