Headlight Replacement Access 2000 Chevy Cavalier
Old 12-16-07, 07:22 AM
Any easy way to access the Headlight/Cornering light? The shroud across the radiator prevents direct access; underside of the plastic clips holding the shroud in place are not accessible, due to the u-shaped metal brace across the top.
Old 12-16-07, 07:43 AM
2 10mm headed bolts should be all that is holding the headlight in place. Open the hood and remove the close out shield which is the black plastic over the headlights and radiator. You will then be able to see what you need to do to get the headlamp assembly out in order to change the bulb.
