2001 chev c 10
2001 chev c 10
rear end posi !!!! i pin out 2 pin out 2 little pins side by side how do get the them out?
2001 chev c 15
Why are you working on the rear end? Are you let's say trying to put in 411 gears?, or did something burn up or let loose due to gear oil leaking out? Just curious.
I have heard that working on rear ends is trickier than some people realize, to get everything right.
The governor mechanism requires a special tool to remove it. That is what I have always used, as it was an essential tool for the dealership. I have never taken one out without using this tool. If no one here can give you an idea on how else to get it out, take the carrier assembly to a GM truck dealer and see if they can do you a favor and pop it out for you.
