2002 Ford Explorer 4x4 not working
Received 0 Votes
02 Explorer with push button 4x4 92K miles. When I push the buttons, it wont engage. I assume that there is a module that controls this but not sure. Also get a loud vibration in the front end when driving down the road. There is a slight vibration in the front end as well. This happens at pretty much any speed. Any suggestions?
Sometimes you can start engaging a 4X4 and it may not be able to complete the process. It may be where you are getting the vibration - something isn't completely locked in. If you disengage the system completely, then try again it may work.
What is the procedure your manual gives you for putting it into four wheel drive ( I assume it's just pushing the 4 wheel drive switch) and taking it out? Does it require backing up about fifteen feet to disengage the front hubs? The later eighties did on the Rangers with auto lock hubs is why I'm asking.
Bob
Bob
Good Luck
The noise/vibration is probably a bad wheel bearing, also very common in that vehicle.
Thanks for the information. I was going to buy one of those, about that year. I had always had such good luck with my Rangers - put on a lot of miles with no problems and the 4 x4 with the autolocking hub setup always worked perfectly..
