horn don't work
Old 12-22-07, 05:45 PM
horn don't work
maybe all my car posts should be merged into a post called flirty1's car problem thread
heres my next problem. i have no horn. i press it and i can hear it click but nothing happens. where is it located and how do i replace it? the clicking is coming from the pasenger side of the engine compartment and can be heard inside the car when i press the horn button. oh and incase you forgot its a 91 olds cutlass ceria
Old 12-22-07, 06:06 PM
chandler's Avatar
The clicking you are hearing is the horn relay doing its job. You can test the horn itself by running a wire from the horn and touching the positive terminal of the battery with the other end. It should sound. If not, the horn is probably faulty.
Old 12-23-07, 01:09 PM
ok but where is it located under the hood don't want to hook a wire up to the wrong item. and what type do i get. theres a low tone and a high tone model available both are under $20
Old 12-23-07, 07:07 PM
Ussualy located behind the bumper assembly just below the the passenger's side headlight assembly.
You may have to pull the headlight assembly out or get under the car with a light and look for 2 big black snails.
Old 12-26-07, 09:53 PM
ok located the horn but it does not look like a snail. it has a plug and play connection and the mounting bracket has 2 bolts.now how do i hotwire the horn so i see if it works. sense the horn relay works i guess the horn is bad. i post pictures tomorrow.
Old 01-07-08, 07:09 AM
ok i took the picture is this the horn
Old 01-09-08, 02:45 PM
ok im assuming thats the horn. now how do i replace it and what tone do i need high or low both are under $20 from autozone. theres a bracket holding it with 2 bolts and a plug and play connection
