86 Camery stuck in drive
Old 12-28-07, 03:20 PM
The transmission is stuck in drive. The shifter moves the cable moves. I am at a loss as to what is wrong with it?
Old 12-28-07, 03:23 PM
86 Camery stuck in drive. Help
Does anyone have a sugestion?
Old 12-28-07, 03:49 PM
I assume automatic?
Old 12-28-07, 03:51 PM
Have you checked the shifting arm on the transmission? If not, follow the cable down to the transmission to make sure the cable is moving the shifting linkage. If that's OK, check the linkage on the transmission to make sure it's rotating the shaft that goes into the transmission casing.
Old 12-28-07, 04:16 PM
chandler's Avatar
Also check the detents actuated by the release button. Do you feel pressure when you press the button?
Old 12-28-07, 04:52 PM
Sounds like the cable either popped off or snapped.
Pop the hood and follow the cable down to the bell crank on the transmission.
You may find that you can change the postition back to PARK by hand or with pair of pliers grabbing the bell crank.
MAKE SURE THE PARKING BRAKE IS ON FIRST or chock the wheels.
Trackbacks are On
Pingbacks are On
Refbacks are On
