2003 Ford Explorer tail light assembly
Received 0 Votes
Good Morning. I need to replace the left (drivers side) rear tail light assembly on my neighbors 2003 Ford Explorer which I accidently smashed. I have no idea how to remove the old assembly, and install the new. Can anyone provide a how to, or perhaps a diagram. I need to do this today, so any quick response will be greatly appreciated
There should be a access panel from within the trunk area of the Explorer. Remove this access panel and you should see that the assembly is just bolted on with a wiring harness attached.
Remove these bolts/wing nuts and the assembly will just pull out.
