2000 Plymouth Neon
Received 0 Votes
2000 Plymouth Neon Heater only warm not hot?
Received 0 Votes
Interesting you should mention this as I too have the a/c pump not only disconnected but removed (when head gasket was redone and mechanic just left it off) and MY heat is poor. My temp gauge and infrared heat check at thermostat show I have plenty of hot water.
And since your gauge goes up 1/3 way, that is plenty. It be due to some other issue like some electrical control is now affected at the blend door or something.
