keyless entry
Old 12-30-07, 08:08 PM
F
keyless entry
hi i have a 2003 dodge durango the keyless entry just stoped working i put in new batteries and it still does not work i also look in the owners manul bt it did not say any thing about why it would work or how to reprogram it , i only have one of them.
thank you
Old 12-30-07, 08:40 PM
HotxxxxxxxOKC's Avatar
See if this works:
1. ENTER YOUR TRUCK AND CLOSE ALL DOORS
2. PUT ON YOUR SEAT BELT SO THE SEAT BELT BUZZER DOES'T CONFUSE YOU WITH THE CHIMING YOU WANT TO HEAR
3. PLACE THE KEY IN THE IGNITION
4. TURN THE KEY TO THE ON POSITION BUT DO NOT START
5. PRESS AND HOLD THE UNLOCK BUTTON ON THE KEY FOB
6. HOLD THE UNLOCK BUTTON FOR 4 SEC. NOW ALSO HOLD THE PANIC BUTTON
7. RELEASE BOTH BUTTONS AND A SINGLE CHIME WILL BE HEARD THIS INDICATION THAT YOU HAVE SUCCESSFULLY ENTERED PROGRAM MODE. ALL FOBS THAT ARE TO BE PROGRAMMED MUST BE DONE SO WITHIN 30 SEC. OF WHEN THE CHIME WAS HEARD.
8. USING THE FOB TO BE PROGRAMMED PRESS AND RELEASE BOTH THE LOCK AND UNLOCK BUTTONS, SIMULTANEOUSLY.
9. A SINGLE CHIME WILL BE HEARD
10. WITHIN FOUR SECONDS OF HEARING THE CHIME PRESS AND RELEASE EITHER THE LOCK OR UNLOCK BUTTON ON THE FOB.
11. REPEAT STEPS 8 - 10 TO PROGRAM UP TO TWO ADDITIONAL FOBS.
12. YOUR TRUCK WILL REMAIN IN PROGRAM MODE UP TO 30 SEC FROM WHEN THE ORIGINAL CHIME WAS HEARD. AFTER 30 SEC. ALL PROGRAMMED FOBS FUNCTION NORMALLY.
Old 01-01-08, 08:56 AM
F
i tried it before and did not work
thank you
