98 ford windstar 3.8 not charging
Received 0 Votes
I have a 98 ford windstar I just bought. I was told it just needed an alternator. I had it tested and it was not good. I put a good alternator on but none of the instrument panel gauges work. the alternator is not getting juice to the battery. Do you have any suggestions.
Thank you
Thank you
Received 0 Votes
I have checked the fuses under the dash and in the engine compartment. they all look good to me.
Received 0 Votes
the technician at autozone said the alternator was receiving 10 amps and the battery 2 amps. Thank you to all that have helped.
Received 0 Votes
Are you certain that they actually have continuity? Sometmes fuses can "look good" but still not be allowing voltage to pass through. If you don't mind my asking, what method did you use to check them? Test light? Multimeter?
Output is measured in volts, not amps in your case. If there is no voltage going to the battery, there is a continuity problem with the cable from the alternator to the battery. Alternators don't receive, they give. Batteries give and recieve, so have them give you the correct information so we can help. You should have about 14 volts exiting the alternator to charge the battery and run your system after it is started.
Received 0 Votes
And just so you know....there are no "technicians" at Autozone....lol
Received 0 Votes
I am guilty of just visually looking at the fuse. I will check them all again with a meter. Thank you.
Received 0 Votes
I heard that,LOL Are there only 2 locations for the fuse panel? under the dash and in the engine compartment. Is there a Mega-fuse? Even with the battery at full charge and a good alternator the instrument gauges dont work. Is there a seperate fuse panel for the instrument panel? Thank you.
Received 0 Votes
Is it just the guages that don't work on your cluster or does NOTHING work? Do the indicator lights come on? Do the illumination lights work?
Received 0 Votes
To test if the alternator is charging, measure the voltage (with your multimeter) across your posative and negative battery terminals with the engine off and then start the engine and measure again. The battery voltage should be anywhere from 11.5 to 12.5 volts with the engine off and should jump to about 14 volts with the engine running. If your voltage does NOT increase when you start the engine then your alternator is not charging the battery. This doesn't necessarily mean you have a bad alternator though....run the test and let us know what you come up with and we can go from there.
It is possible that the instrument cluster not working is an entirely unrelated issue from your alternator problems.
Received 0 Votes
To further this test, take readings with your probes on the battery posts themselves, then on the cable clamps. You may have crud under the clamps and it is preventing good contact. Your reading from the alternator will be accurate on the clamps, and what the alternator is giving the battery can be measured on the posts, so the drop in voltage tells me you have crud under your clamps.
Received 0 Votes
yah, the voltage drop test as suggested by Larry is definitely a good next step. Also, if you can get to the back of the alternator, there should be a main wire (it will be the SINGLE big one) that bolts onto the back. Make sure that wire has battery voltage on it at all times. You can also run the voltage drop test from there as well to make sure your cable from the alternator to the battery is good.
Make sure ALL the wires are plugged into the alternator and double check ALL the fuses.
If all that checks out good, I think it may be time to start searching for a good wiring diagram. There's not alot more probing around that you want to do until you are sure what you are probing. Many late model instrument clusters are actually computerized "modules" that interface with the PCM and BCM to get their data. Jumping or probing the wrong wire without knowing what it goes to or through could potentially cause damage to your PCM or BCM or both.
Received 0 Votes
Sorry i haven't got back to you all who have helped me with my charging problem as I do not have a garage and we have had some inclamate weather. Yesterdays high temp. was 19 degrees.BRRRR. I am going to check all fusible links today. I have bought a repair guuide at autozone wich has been helpful with wiring diagrams. I will post my results later today. Thank you, Dave
Received 0 Votes
Alternator voltage from big wire should be 14+ volts. It appears you have a bad alternator. You can have it tested at most parts houses and get a replacement at the same time.
Received 0 Votes
Thanks for the reply larry. But what is causing none of the instrument panel gauges to work. (gas gauge,speedometer,tachometer,temperature and ignition warning lamp.)?? Also why dont some of the fuses under the dash show good when I put a test light on them . I checked them with the ignition on and off?
Received 0 Votes
Here are the results I have came up with. With the engine off the battery has 12.28 volts, with engine on battery has 11.8 volts going down. The alternator big wire with engine off is 12.28 volts and with engine running is 11.80 going down, the yellow wire on the alternator with engine off is 12.28 volts with the engine on is 10.5 goiong down, the light green and red wire on the alternator with engine off is 0 and with the engine on is .04. I checked the fuses in the engine compartment and they all checked out good with a test light. I also checked the 3 fusible links coming out of the engine compartment fuse box and they tested good with a test light. I checked the fuses under the dash and some of the fuses did not test good with a test light even with the ignition on. Does this help you all in helping me solve my charging problem?? Thank you,Dave
#21
Received 0 Votes
GOOD NEWS MEN I got it charging!!! It turned out that the exit wires out of the power distribution box in the engine compartment were oxidized and I took a piece of light sandpaper and shined them up. Hooked them back up hit the ignition and I had lights!! The alternator was making 14.5 volts. I took it for a test drive for about 10 miles with the heater and headlights on , went back home, shut it down then started it right back up. It ran good and charged good.
Thanks for all of your'e alls advice . It was much appreciated and Most of all I learned alot about electical wiring and charging systems.
Have a great day,Dave: thumbup:
