Toyota Highlander power window problem
Received 0 Votes
Hey guys
I have an 04 highlander limited, and am having a problem with the drivers side window.
It will go down but when I go to close it it will stop and reverse itself back to the full down position.
It varies as to when it will go up maybe 1" or 1/4 to 1/2 way up then back down. If I grab the glass it will stop and if I lift it when I hit the switch it will go all the way up.
This is intermittently, the dealer already changed some part that was over $400.00 (was not the motor or regulator, and it was a warrentee)
Any suggestions???
Thanks
Rob
Any suggestions???
Thanks
Rob
Toyota has an automatic safety reverse so that arms, heads, necks, etc. don't get caught in the window.
It sounds like either the window is binding which would make it think that there is an obstruction, or the sensing mechanism is too sensitive.
