Overheating Occasionally
Received 0 Votes
Anyone have any idea of what can be wrong?
Received 0 Votes
Here is ONE idea: Make sure radiator fan is working (comes on after a while when the temp gauge climbs). At idle you need one; at highway speed you don't. Which could explain your problem.
Also note how much coolant you have to add and how often. IF you just fill it up and you idle it and then it overheats anyway, and then if you recheck the coolant level and it is good within reason, then I would not blame the coolant leak, and instead simply blow that off as a coincidence.
